Hi, I stopped at a garage today and after getting back into the car, the eml light started flashing and the engine would turn over but not fire. Did a pedal test and got 1614 which I believe is something to do with the ecu getting the wrong code from the key transponder? Anyway after about ten minutes of trying the car started as normal and eml went out. This happened once before in 2011 and has been fine ever since then until today. Even after the incident today, it worked fine afterwards when i stopped again 15 minutes later. Does anyone know the likelt cause of this (im hoping key chip and not ECU) and can the clocks be a cause of this as i pressed them a few times before it started again? Cheers
