1 - 10 of 10 Posts
Corsa C problems
Hey all, Im currently driving a Corsa C snd its started being a but of a shunt.
It can be fine for ages then its starts playing up. What happens is that when you start it, it will run for about 2secs then it cuts out. You can instantly tell when it will do this as the right row of instrument lights on the dash doesnt light up. I have found a way to fix this (open and close bonnet) but this doesnt always work. Does anyone have any clue why this is happening?
cheers
Lucky
ah right sorry.
erm, might need to be plugged in if the engine managment light is coming on. that will tell you your problem.
opening a closing the bonnet? lose connection somewhere?
nothing to do with an immobiliser i take it? only a guess as it could have a bonnet sensor thats dodgy so when you open and shut the bonnet it resets it?
it might be the connection on the back of the clocks, done quite a few with the same prob, bang the dash to see if the lights come back on. if they do then take the clocks out and use a small amount of foam to hold the connector at a better angle. hope this helps
1 - 10 of 10 Posts
