The original unit in my 2004 Corsa is 'skipping' on the CD player, so I intend to fit replacement head unit, with the 'in-fill' panel. Are there any radio makes / models, which will present the station info. on the display above the unit, and also retain the use of the steering-wheel controls? Any advice would be much appreciated, thank you, as have not had to change one of these before.
