Hi,
I have a 55 plate Corsa C and water has been leaking in to the passenger footwell on occasion.
I believe this is a common problem with this model. I changed the indicator relay in the BCM box a few days ago and not all of the screws were present. Is it likely that by just replacing them will solve this problem?
I phoned my local Halfords autocentre and they estimated around £300 to sort out as it involves sealing various entry points.
Cheers.
It usually comes in the drivers side around the brake servo bracket on the bulkhead, N/S unusual, i have heard that box you spoke of can leak, some people put silicon sealant around them...if its coloured water could be anti freeze from the heater....Fred in Essex
Hi,
Cheers.
After a spell of rain, mine slops water onto the floor immediately after I accelerate from standstill ! (Usually onto the passengers ankles !) Great design. ��
Presumably this water is entering around the relay box .. Both drain holes are clear...We've emptied a watering can behind the battery area , but no leaks show inside.Crazy
