Hi all, this could be a silly question but I'm not great with knowledge on cars so bare with me. I drive a corsa C 01 plate and have just ticked over 100k miles and am concerned about wanting to maintain the quality of my car. I don't know if it is chain driven, or belt driven and wondered if anyone could give me any hints?
As I say, may be a silly question, but my knowledge is limited and different forums say different things.
Also, my car does not like going over 3000 rpm. It will judder as if I am in the wrong gear, however should definitely be able to handle much more than this. I have recently had a new air flow sensor fitted, and the problem only seems to have occurred since then. However the new sensor has fixed a previous problem I had where the car used to rev itself?? Any ideas will be much appreciated. Thanks in advance.
2001 Corsa 1.2 engine is chain driven, regular good quality oil changes should keep the engine o k, but if its got a noisy rattle it needs changing
I would say it is chain driven.
I look after a 2000 corsa B 1.2 X plate - and it is chain driven. I guess your engine will be basically the same.
I assume by "new air sensor" you mean the MAF = Mass Air Flow sensor = the cylindrical bit that plugs in the air ducting between the air filter box and the throttle body.
This really must be a genuine bosh part. If your "new" sensor was an aftermarket bit off ebay then there is no guarantee it will work correctly.
I had a similar issue. Original MAF (bosh) died. Car would lose power above 3500rpm. Replaced this with a "new" cheapo MAF. Car would now rev upwards all the way - but was a b*tch to start and would barely idle when cold. Throw away cheapo ebay MAF, put proper Bosh one on - car is now reliable and sweet.
Hi there i cant say for sure, but if its a 3 cylinder its almost certainly a chain, and at idle after a lot of miles they do rattle, have a look on the drivers side of the engine, if it has a chain it prob wont have a removable cover, if it doesn't have a chain it will, if it has, remove cover and have a look, or just prise the cover back a bit up the top and see if you can see a toothed belt, if it has one they should be changed at regular intervals, if they break apart from breaking down they can cause a lot of mechanical damage to the engine..hope this helps...from Fred in Essex.
