Its me and my sister's corsa at it again
30k km back i had to replace the camshaft due to some of the lobe's having worn down to allmost nothing left.
so now with the milage at 223k km it ran a big end bearing, when i opened the engine i noticed that the crank thrust is completely worn down, so much so that the cranck started eating into the block, this probably caused stree on the big ends causing it to fail.
My question, why did the thrust fail, i know my sister's driving style and its not because she rides the clutch.
What i noticed is that there is a spring behind the clutch thrust bearing keeping it permanently in contact with the clutch, i also know the car's history so the must be factory fitted, could this spring cause the damage described above, is that spring necessary to be there or can i remove it??
Any help appreciated.
its a 2006 corsa 1.4 8 valve
