Hi guys, new user here.
We have just returned from a 3 week holiday and my son's 2010 1.0 Corsa refuses to fire up.
The engine is turning over but not firing. I am erring on the side of fitting a new battery just to make sure that is not the problem. If I replace it, are there any pointers I need to know like radio code, clearing the ECU etc?
The last thing I want s for the ecu to screw up and I have to spend a fortune replacing it. Should I remove the battery and leave the new one out to clear the ECU - or replace it immediately?
Also, the windscreen wiper mechanism looks like it is goosed. I can see a ball joint has come away from the plastic holder (which has a crack in it so the 'ball' section drops out) and the wiper is not working as it should. Is there a replacement plastic bit I can get, or do I need to replace the entire mechanism? I was thinking I could grease up the joint and then secure the plastic ball joint holder with a tie wrap - would that work?
I have personally had Vauxhalls for years, but this Corsa is becoming a real pain in the backside!!
Any advice. tips or suggestions gratefully received :thumbs_up:
Cheers
Paul
Edit
I think I have managed to sort the wiper problem and have the battery on charge. Hopefully, the bloody thing will fire up once the battery is reconnected.
Welcome to the Forum.
There is nothing to be gained by leaving the battery disconnected.
These engines do like a fully (or at least, reasonably) charged battery, so hopefully, charging it will solve the problem.
Can you hear the fuel pump 'priming' when you switch 'on' the ignition? -If so, then that is one item that is working.
I must say that I am not too keen on the idea of a cable tie holding the wiper mechanism together for more than a 'get-you-home' measure - The last thing that you want in the middle of a thunderstorm, is for the wipers to pack up!
Do let us know how you get on after the battery is fully charged.
Regards.
