1 - 20 of 22 Posts
hi all new to forum.. i have a slight problem with a corsa diesel 1.7 97 r reg i bought the car with a bump(slight) from a salvage yard and the car wont start it just turns over and over does the car have a fuel cut off switch? and does it have a immobilisor as ive been told it may need key coding has i only have one key any help needed thanks in advance....
bit of a up date
just spent an hour on trying various things and i have managed to get to the stage where it turns over and fires up for a couple of seconds then dies does this sound like shortage of fuel?
Corsa's do turn over if the immobiliser is buggered Mark.
They will usually start and then cut out straight away.
Open up your key and see if there is a chip in it. Sounds like an immobiliser problem to me.
opened key up and if its the little grey thing about 1cm long then yes it has a chip. Is there anyway i can reset it myself because if it has to go to vauxhall thats another problem.
You may possibly have to get another ecu and key chip if it is that at fault. It's a cheaper option then going to Vauxhall.
There is no way of getting around the immobiliser.
Don't get one from breakers yard, they will charge too much. Look on ebay, they can be bought for around £10.
You'll need to get a matching chip and ecu.
Yep it should be.
i will think before typing in future:eek:
my car doesnt turn over when the immobilizer is activated. Just get a beep an thats it. Tried running a paperclip test to see if it throws up any fault codes?
1 - 20 of 22 Posts
