Full set of mounts and rubbers in this picture £50 the lot
Gear linkage in this picture extended for F16/F18/F20 box. Metal rod. £50
Conversion driveshafts with CVs, complete, £100
Big block hubs in picture above, pressed into Corsa/Nova/Tigra knuckles £60
288mm brake kit as per picture above. No lip on discs, good working order £50
Eibach springs on Koni shocks. Cost a fortune new.
Yours for £100
Alloy FMIC with pipework, joiners and clamps. Not sure if it's complete but looks close enough.
£80
Big block hubs with bearings pressed into Corsa B / Tigra steering knuckles (as per picture above - everything minus the brakes) - £60
Conversion shafts, I'm told they are Mtec. Fit F16/F18/F20/F28 in Corsa/Nova/Tigra. One CV boot has a slight tear
£80
Single vee conversion kit. Consists of alternator with brackets, belt, tensioner and pulleys. Everything you need
£40
3" turbo back system. Including TX 3" downpipe and powerflow exhaust. Most of it's 3" with a couple of 2.5" pieces, and 3" tip to backbox
£150
Full set of engine mounts (2x engine, 1x gearbox), still on engine at present but will remove for buyer
£50 for the lot
F16/F18/F20 conversion linkage (pictured above), complete, £50
C20LET engine loom modified for Corsa B / Tigra plug, works perfectly / tested
£70
No offers thanks
Yours for £100
£80
£80
£40
£150
£50 for the lot
£70
No offers thanks
