1 - 20 of 40 Posts
Having a clearout of the garage so here goes -
Brand new Goodyear cambelt kit c20xe - £50
Coilpack c20xe engine loom - £20
Corsa gsi spoiler basplate - £5
Vauxhall nova haynes manual as new. - £10
Haynes/max power Nova book - £10
Front 60mm springs (gmax) - £25
Motronic 2.5 ECU (FX) possibly chipped. - £25
100mm rear springs (brand new) - £65
c14se coilpack - £5
Standard rear corsa shocks - £10
c20xe throttle body with 6pin TPS - £10
Nova Rad fan - £10
Side skirts Brand new (not sure for what but corsa length) - £10
c20xe manifold adapted to fit to a Nova system with flexipipe - £25
Peco stainless box for making a custom system - £10
Corsa QT ECU - £10?
Corsa QX ECU - £10?
corsa fuel pump - £5
As new Corsa cat - £30
c20xe manifold with lambda - £15
Single gmax 60mm spring (ideal if yours snapped) - £5
Peugeot 106 xsi spoiler - £15
Clio Splitter (came off a 172 will fit others) - £20
Corsa sri smaller 3 spoke steering wheel - £5
Early c20xe SFI top box with good rubber - £5
Corsa sri wheel centre caps/plates (set of 5) - £10
Interior light with on/off switch to fit a corsa - £2?
2 sets of standard front shocks - £5 each set.
Corsa n/s headlight - £5
Pug/saxo/106 interior light - £2
Apex 50mm yellow front springs - £25
BRAND NEW still in packaging FK rear springs (60mm) - £45
15" jbl 1000w sub - £30
good c20xe starter motor - £25
Custom Sub box (takes two 12" subs and 2 components and space for an amp - offers
collection only for now (Maidstone Kent) as no postage costs have been worked out. Loads of other little bits so if you need anything just ask
Pics on request. :)
Discussion Starter #4
Backbox isnt a backbox mate its just a box with no tips just striaght pipe on each side. for when making a custom system up can either use it with a tip as a backbox, or use it as a centre box for something.
Rear springs are brand new been laying around for a month or so. Never been fitted so no pics of them on but heres a pic of them off...
Discussion Starter #8
There you go mate. Not sure what they were made for but they are new, made of thin fibreglass i think, and are the right length for a corsa.
Discussion Starter #13
how would they be attached?
I should imagine you could fix them at each end with a screw or something and then bond/tiger seal on the skirt along the edge.
pic of sub box mate? and you got any amps forsale?
Il get a pic tonight. Got one jbl amp but its pretty ****ed so not really worth your time lol
Also Postage on the springs would be about a tenner i would have thought once boxed and bubblewrapped up?
reckon you could get a pic of the skirts held/taped up to a corsa? lol
il probably have them haha just not sure what they would look like?
Discussion Starter #16
Speakers not included. Made out of 8mm MDF (i think) and sealed inside. Seperate chambers for each sub and for the 2 components. Space for an amp underneath. All covered in dark grey sub box carpet.
turns out the skirts are not flat along the top edge (see pic) so could either leave them like that and possibly fill with sealent when you bond them on. Or fibreglass the lower cut bit to the same depth as the rest. Or you could simply cut off the rest so its all the same level. Either option would work :)
Discussion Starter #18
Lol not to worry. Just let me know when you want to get them and il save them for you. how far are you away mate? im in maidstone me17.
1 - 20 of 40 Posts
