hi, i have just got a corsa and i dont know much if not anything about engines but my engine light and traction control lights have turned on, TC light sometimes goes of but comes back on again, my engine runs fine and smooth until it warms up then becomes a bit laggish and fluttery.
any one got any ideas
cheers
oh yeah its a corsa c
A common problem is cracked ABS rings, or damaged wiring to the sensors, that can cause the TC light to show. But best thing is to read the codes. Either use a code reader, or look in the tutorial section - there's a thread there how to read the codes on this model.
thanks but i solved the engine problem by replacing coil plugs which stopped the engine judder and flutter acceleration, since i replaced it the TC light has turned off and only flashes when wheels spinning haha. so think problem solved. thanks :thumbs_up:
