My W reg 1.0L Corsa B (X10XE) 60k miles is stalling on me after about 10 minutes of driving, and will not restart.
OPCOM is giving a fault code of "P0335 - ( 0 ) - No Engine RPM Signal" following a stall.
About three weeks ago I added half a bottle of Redex to a full tank of fuel for the first time (have owned the car for 14 years), and am concerned years of sediment and junk has now been lifted and thrown into the fuel filter. The problem started after doing about 100 miles of driving in the car.
A mobile mechanic has also discovered white cream on top of the oil (dipstick is however clean), and a slight leak from the oil temperature sensor. Emissions have also been up a little from the exhaust for the last six months or so, and I found the coolant reservoir was almost empty last week (have now topped this up).
Mechanic thinks the fuel line is fine (though not sure what checks they have done on it), and instead think the crankshaft sensor and oil temperature sensor need replacing - I'm told these are cheap parts and very quick to fit, so cost should be low.
Given the above, this means I have three questions:
1) I imagine the professional mechanic is a better judge of these things than me, and replacing a fuel filter requires depressurising the fuel system which I don't feel able to do. Does anyone have any concerns with the mechanic's conclusion?
2) How best can I get the car to a garage? Mobile mechanic says he can't replace the crankshaft and oil temperature sensor at the roadside. I needed the breakdown man to get me home when I first broke down, so breakdown won't take me to a garage without a massive charge.
3) My dad suggested trying some cylinder head gasket sealant (about £40 from Halfords) - could cylinder head explain the issue I am getting and does this sealant work?
