can an amp be connected to the phono output on another amp with no problem.
my friend has 2 amps in his car, and there are 2 y splitters at the headunit, however one of the cables is dodgey.
What i was thinking of doing is using 1 cable to run to 1 amp then from that amp run a phono cable from the output on the first amp to a second one.
The reason im asking this is because i dont know if the phono out (next to the phono in) are amped or not.
jackassuk56
jackassuk56
