Different problem to the one below though.
I have just got a Corsa C and have debadged all of the writing part (vauxhall corsa 1.7 DTI) and am now left with only the Vauxhall logo on the back.
As i got about half way through pulling it off i noticed that the badge has a small clip on it that goes into the car and if i remove it, I will be left with a small hole about 3mm wide in my boot!
Has anyone else had the same problem? And how did you go about resolving it?
Im a bit of a modifying noob but i want to avoid filling and respraying the boot!
Cheers.
i think most people just put the corsa badge over the top or some other
badge, if they dont fill and spray.
The 2nd coming
you dont really wanna be removing that badge unless you want to spray, replace it or play with filler ;)
