what routine would you recommend to a beginner as regards to wash/polish/wax?
what products?
Well, the routine is as you said... Possibly start by soaking the lower part of the car with some degreaser/all purpose cleaner. Then rinse, followed by a 2 bucket wash with a lambswool mitt.
Rinse the car, and pat it dry with a plush, soft drying towel.
As you say you're a beginner, I'll assume you're polishing by hand. Hand polishing won't really remove anything as you cannot generate the heat, or RPMs to remove the marks. Your best bet it to "fill" any swilrs the best you can with something like Dodo Juice Lime Prime, AG SRP, Poorboys Black Hole/White Diamond.
Finish this off with 2 coats of wax to ensure even coverage. Depending on the wax, and also the shampoo you use, the wax should stay durable for 3-6 months, and all you need to do is a regular wash and dry.
-Mat-,
How do you stop spatter when using a rotary polisher?
Regards, Dan
Apply the polish to the pad, and dab it around the area you are going to polish. Also, spritz the pad with some Pad Prime before starting.... Once you have applied a bit of polish, the pad will be constantly primed due to polish soaking in. So further applications of polish should be less.... Remember, spread/dab it around, and keep the pad flat, and speeds low until it's evenly spread.
what would be the best way to remove light swirl marks and slight scratches from the paint work without using a machine polisher
cheers daz
As mentioned above. You won't be able to really remove them, but you will have a better chance of "filling" them.
What does claying actually do ? I have never clayed my car or bike ever :/
Clay removes bonded contaminents such as microscopic pieces of tar that tar remover may have missed, iron filings, tree sap etc.
Should clay be rubbed or rolled across the paint work?
And Would a snow foam wash be enough for a quick clean, without getting the buckets out?
Clay should be rubbed. Using plenty of lube, and doing about a square foot at a time.
If the car has plenty of wax on it (like mine), then a foam and rinse can be enough. It'll never fully clean the car, but can certainly improve the looks if you only have 5minutes to spare.
