I want to wire my comps up to my amp, so the wires need to be fed into the door, I don't want to connect them up to the ISO connector anymore as I tried once before and I made a bit of a mess of that, also the wires are totally different sizes so it's awkward to connect them, and also again I don't want to have to take my head unit out again, the way some of my wires are routed I'd have to unplug them to get it out lol. Anyway, point is, is it simple enough to use the existing door wiring loom to pass my speaker wires through into the door? (I mean the rubber tube thing in amongst the door hinges.) As far as I have gathered there are connectors on each end with loads of holes, some are used and some are not. I thought surely I could make a bigger hole where there are no wires in the connector and pass my wires through that way? Main thing though is how do I unplug it so I can see the pins? Just pull it off or does it need to be twisted?
