Hi All,
Changed the front drivers side wheel bearing on the Corsa C.
Had to take the Driveshaft out of the gearbox.
Slid the driveshaft back into the gearbox, there wasn't any resistance.
Gave a little tug on it, and it didn't pop out.
Popped the hub on, and it still has the normal few mm play back forth.
I'm not 100% sure it is located correctly.
Does the driveshaft make a definite 'pop' or 'click' to show it is located correctly?
Is there any 'How To' guides on this?
Thanks in advance
The noise should change when it goes in if that makes sense. Sometimes they slip in easy, passenger on mine is a nightmare, drivers is easy as a tiny push
