Sorry forgot to mention it was off a 1.2Which model - eg the 1.0, 1.2 & later 1.4 chain driven engines have a blanked port on the EGR where the coolant temp. sender for the gauge used to be.
Thanks a lot TaurusOK - well as said, some later ones blank off the point where the temp. gauge sender used to go. Also, later ones use a different gas flow so if you look at the EGR gasket for the X12XE and the Z12XE you will see they are different.
