Only the drivers side is currently working
Any ideas what could be wrong with the other? Would it be likely to cost an arm and a leg to put right?
Got a really bad feeling it is the wiringCould possibly be your motor, or a switch problem, or worst case, a problem with the wiring.
The first two possible problems are cheap and easy to fix, the third requires a lot of fault finding so costs could be high.
