Don't quite understand what you mean, but if you have fitted a new chain and /or belt, you have to align all the marks exactly...if your one tooth out your in trouble, then are you trying to put the MIL light off, if so put a cheap code reader on it and clear the codes, or maybe if your lucky disconnect the battery for 5 minutes, you will loose radio code if you have one,...from Fred in essex
