1 - 8 of 8 Posts
Hello all,
I've got a 55 plate corsa c twinsport sxi I'm get the engine emission light flash then staying on when I do 60 mph then it goes off when I restart the car. I have had the ecu replaced £££ the cranksensor £££ the spark plugs and the coil pack. I'm pulling my hair out thinking what else can it be. Any advise would be helpful as I haven't got a clue about cars so have to go to a garage and think they just trying to do me over.
When was it last serviced?
Why was the ecu replaced and coil pack :/
The coil pack was 1st replaced as it was loosing power/misfiring but that didn't do anythink so they said it was the ecu so I had that replaced thinking it would sort the problem out but no it hasn't. But the problem only seems to be when I'm on a A road doing 60 or motorway when I'm doing 70. Was last serviced September but I got the car November so that's was the car salesmen said and its stamped in the service book
Service to some places is "oil and spark plugs" this is a half arsed service.
I know but would that set off the emissions light. I just don't know what to do next I'm taking it to the garage I had the ecu replaced. But the car is doing me heading at the moment I just have somethink done then the problem comes back and carnt go on the motorway
And why is it only happening when doing above 60 then the engine emissions light stays on its just wired and I don't know what to do next as I can not go on the motorway
EGR valve - try cleaning it, if not then blank it off.
The codes won't always point to the EGR being the culprit - you may just be getting a misfire code. It can be tricky to spot, but if you can monitor live engine data whilst on the motorway (ie a passenger monitors it on something like Opcom) then I bet the EGR readings are freezing at higher speeds.
For that light to be on I would have checked egr valve , lambda sensors and then cat with it being emissions related
1 - 8 of 8 Posts
