Firstly, have just introduced and said Hi. New to this forum. Tried to find similar threads, as well as searching. Nothing coming back on ECU or engine management.
So I start with an apology if in the wrong area or it has been covered before.
So is ECU deemed as engine, ergo mechanical, or as I expected to do with Electronics?? - hence where on the forum to look.
So to get to the nitty gritty.
As my intro says, I have a corsa,(C - 2002) bought as a donor with an ECU fault. Bought for other parts, but it is in better condition than the original, so I would like to get both going.
On a whim, I bought a third Corsa, same year (comfort), but got it remotely, i.e. I am away working sent my son. Checked it was running, what it had failed MOT's on etc.
What I forgot to check was the engine. Turns out it is a 1.2 and not a 763 like the other two.
so to my question.
I would prefer not to engine swap, so Is the ECU from the 1.2 able to go into the 763. Basically, can I change the configuration of the ECU???
I have just purchased the op-com unit to reset ECU etc.
anyone any ideas
cheers
Mike:laugh:
alm:
so to my question.
anyone any ideas
cheers
Mike:laugh:
