1 - 15 of 15 Posts
Mini Rant time. Spent 700 getting my car fixed for mot , (nearly half its value) which it passed, and then there was still an issue. Everytime I changed gear and tried to accelerate the car sort of stuttered for a few seconds then took off. After a while the Engine light came on so I took it to the mechanic. There was a bit of oil around the casing of the air filter so i watched him blast that all off and clean it out and took the car for a spin and still the lag was there.
So I left it with him and a week later get a call to say he has replaced the throttle box and air filter meter, another 180 but I couldnt give a monkeys as long as it was going grand. But it wasn't. Was ok for about a day, then the same prob occured and on my way to the gym this morning the engine light came on. Lag when changin gear and accelerating!
It's really getting to me now. I'm actually waiting to phone the guy at 9 and have a go but I don't even know if I have a leg to stand on and I know it's gonna be more money. Taxx is due in 2 weeks too.
Hope no one minds me moaning, ha, and if anyone has any ideas as to what the problem might be, I'd be open to ideas. A grand down the drain in a month for a 06 1.2 sxi :(
has he read the codes? or just guessed?
As far as I am aware he has read the codes. I seen him plug it in so I think he has but he did seem a bit baffled by the whole thing and said that he thinks it may be something to do with the 'brain' of the car. He said he cleared all the faults but wasn't surprised that I was phoning again, I think he is at a loss to explain
If you've got a laptop invest in opcom, read the codes yourself, and post the results here.
It will pay for itself the first time you use it, and you will know first hand what the codes are present, be able to trigger various components independently and monitor live engine data. Otherwise it's just a matter a guesswork.
UPDATE: Got the car back. He said something about the voltage of the fuse just randomly dropping so he had to wire it so it was earthed and this should sort it out. He didn't charge me any more for it cus he said I'd already spent enough.
However after about 30 miles the Engine Management light came on again!!! The car seems to be fine but I'm pretty in tune with it and it does feel a bit like when I hit 50-60 and accelerated sometimes picks up a bit or drops too much. Any ideas guys. It's slowly but surely breaking me:( financially and emotionally, ha
Pro Spanner Wielder
As this is a facelift corsa C, can you not do the pedal test on it and find out the codes yourself for free.
Get in car, pressdown brake pedal and throttle pedal at the same time. With them both pressed down, put key in and turn it to ignition (just ACC, dont start the car). The spanner light on the dash will start to flash out the codes to you. For example, code P0110 would flash out as 10 short flashes, then a gap, then 1 short flash, a gap, 1 short flash, a gap and then 10 short flashes. This is because 0's are represented by flashing 10 times.
Note down the flashes and report back what codes it tells you.
To me this sounds like lambda sensor issues, but the issue is that a LOT of things on these engines cause roughly the same symptoms, rough running, jerky acceleration, poor start, all those things can be caused by almost every sensor one way or another.
Do the pedal test and see what codes are being reported.
Dave
Pro Spanner Wielder
And for reference, here are the codes and there related faults:
Code:
P0030 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 1) C-29
P0036 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 2) C-31
P0100 Mass or volume air flow circuit high input C-10
P0100 Mass or volume air flow circuit low input C-10
P0110 Intake Air Temperature Circuit High Input C-12
P0110 Intake Air Temperature Circuit Low Input C-12
P0115 Engine Coolant Temperature Circuit High Input C-11
P0115 Engine Coolant Temperature Circuit Low Input C-11
P0115 Engine coolant temperature circuit malfunction C-11
P0120 Throttle Position Sensor (TPS) Circuit 1 Voltage High C-09
P0120 Throttle Position Sensor (TPS) Circuit 1 Voltage Low C-09
P0120 Throttle Position Sensor 1-2 Correlation C-09
P0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) C-30
P0130 O2 Sensor 1 Circuit Voltage Low C-30
P0130 O2 Sensor 1 Open Circuit C-30
P0130 O2 Sensor 1 Incorrect Signal C-30
P0134 O2 Sensor Circuit Open (Bank 1 Sensor 1) C-30
P0135 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) C-29
P0135 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1) C-29
P0135 O2 Sensor Heater Circuit Open (Bank 1 Sensor 1) C-29
P0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) C-32
P0136 O2 Sensor 2 Circuit Voltage Low C-32
P0136 O2 Sensor 2 Open Circuit C-32
P0139 O2 Sensor 1 Incorrect Signal C-30
P0140 O2 Sensor 2 Incorrect Signal C-32
P0141 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2) C-31
P0141 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2) C-31
P0141 O2 Sensor Heater Circuit Open (Bank 1 Sensor 2) C-31
P0170 Rich Exhaust C-30
P0170 Lean Exhaust C-30
P0201 Cylinder 1 injector circuit high C-23
P0201 Cylinder 1 injector circuit low C-23
P0201 Cylinder 1 Injector Circuit Open C-23
P0202 Cylinder 2 injector circuit high C-24
P0202 Cylinder 2 injector circuit low C-24
P0202 Cylinder 2 Injector Circuit Open C-24
P0203 Cylinder 3 injector circuit high C-25
P0203 Cylinder 3 injector circuit low C-25
P0203 Cylinder 3 Injector Circuit Open C-25
P0204 Cylinder 4 injector circuit high C-26
P0204 Cylinder 4 injector circuit low C-26
P0204 Cylinder 4 Injector Circuit Open C-26
P0219 Engine overspeed condition C-43
P0220 Throttle Position Sensor (TPS) Circuit 2 Voltage High C-09
P0220 Throttle Position Sensor (TPS) Circuit 2 Voltage Low C-09
P0220 Throttle Position Sensor 1-2 Correlation C-09
P0230 Fuel pump secondary circuit high C-07
P0230 Fuel Pump Relay Open Circuit C-07
P0300 Misfire Unidentified Cylinder Detected B-21
P0301 Cylinder 1 Misfire Detected B-22
P0302 Cylinder 2 Misfire Detected B-22
P0303 Cylinder 3 Misfire Detected B-22
P0304 Cylinder 4 Misfire Detected B-22
P0325 Knock Sensor 1 Circuit no Signal C-27
P0335 Crankshaft Sensor Incorrect Signal C-06
P0335 Crankshaft Sensor Open Circuit C-06
P0340 Camshaft Position Sensor Circuit No Signal C-13
P0340 Camshaft Sensor Incorrect Signal C-13
P0351 Ignition Coil 1 High Input B-23
P0351 Ignition Coil 1 Incorrect Signal B-23
P0352 Ignition Coil 2 High Input B-23
P0352 Ignition Coil 2 Incorrect Signal B-23
P0353 Ignition Coil 3 High Input B-23
P0353 Ignition Coil 3 Incorrect Signal B-23
P0354 Ignition Coil 4 High Input B-23
P0354 Ignition Coil 4 Incorrect Signal B-23
P0420 Catalyst Efficiency Above Threshold C-31
P0443 Evaporative emission control system purge control valve circuit shorted C-28
P0443 Evaporative emission control system purge control valve circuit open C-28
P0460 Fuel Level Sensor Circuit High Input C-14
P0460 Fuel Level Sensor Circuit Low Input C-14
P0460 Purge flow sensor circuit malfunction C-14
P0500 Vehicle speed sensor malfunction B-10
P0530 A/C Refrigerant Pressure Sensor Circuit High Input Air Conditioning System B-05
P0530 A/C Refrigerant Pressure Sensor Circuit Open Air Conditioning System B-05
P0560 System Voltage High Input C-04
P0560 System Voltage Low Input C-04
P0565 Cruise Control SET and RESUME active C-17
P0566 Cruise Control Off Signal Circuit no or Incorrect Signal C-17
P0567 Cruise Control Resume Signal High Input C-17
P0568 Cruise Control Set Signal Circuit High Input C-17
P0571 Brake Switch Circuit Low Input C-15
P0602 Powertrain Control Module Not Programmed C-02
P0602 Security Code Not Programmed C-02
P0602 Vehicle Identification Number Not Programmed C-02
P0602 Variant-Coding Not Programmed C-02
P0606 Control Unit Re-Initialisation C-02
P0650 Malfunction Indicator (MI) Control Circuit High C-36
P0650 Malfunction Indicator (MI) Control Circuit Open C-36
P0700 EOBD Error stored by Transmission Control (TC) Modul B-06
P0700 MIL request from Transmission Control (TC) Modul B-06
P0704 Clutch Switch Input Circuit High Input C-16
P1110 Variable Intake Manifold Signal High C-33
P1110 Variable Intake Manifold Signal Low C-33
P1110 Variable Intake Manifold Open Circuit C-33
P1120 Accelerator Pedal Position Sensor 1 High Input C-08
P1120 Accelerator Pedal Position Sensor 1 Low Input C-08
P1120 Accelerator Pedal Position Sensor 1-2 Correlation C-08
P1122 Accelerator Pedal Position Sensor 2 High Input C-08
P1122 Accelerator Pedal Position Sensor 2 Low Input C-08
P1130 O2 Sensor 1 Signal Out of Range C-30
P1130 O2 Sensor 1 Signal no Activity detected C-30
P1130 O2 Sensor 1 Signal Switching Time Error C-30
P1170 System too rich (Bank 1) C-30
P1170 System too lean (Bank 1) C-30
P1230 Main Relay Circuit Voltage High C-03
P1230 Main Relay Open Circuit C-03
P1326 Knock Control Maximum Spark Limit Cylinder 1 C-27
P1327 Knock Control Maximum Spark Limit Cylinder 2 C-27
P1328 Knock Control Maximum Spark Limit Cylinder 3 C-27
P1329 Knock Control Maximum Spark Limit Cylinder 4 C-27
P1372 Crankshaft Sensor Segment Error C-06
P1372 Crankshaft Sensor Adaption Error C-06
P1481 Fan Relay 1 Circuit High C-34
P1481 Fan Relay 1 Signal Low / Open Circuit C-34
P1482 Fan Relay 2 Circuit High C-34
P1482 Fan Relay 2 Signal Low / Open Circuit C-34
P1500 Electronic Throttle Control Motor Failure C-09
P1520 Powerstage Currentless C-02
P1525 Limp Home Position Error C-09
P1526 Throttle Position Adaption Error C-09
P1526 Throttle Position no Adaption C-09
P1526 Limp Home Adaption Error C-09
P1526 Lower Limit Adaption Error C-09
P1530 A/C Relay Voltage High Air Conditioning System B-10
P1530 A/C Relay Circuit Open Air Conditioning System B-10
P1540 Air Conditioning Pressure Invalid Signal Air Conditioning System B-10
P1540 Air Conditioning Pressure Signal High Input Air Conditioning System B-05
P1540 Air Conditioning Pressure Signal Low Input Air Conditioning System B-10
P1540 Air Conditioning Pressure Open Circuit Air Conditioning System B-05
P1550 Electronic Throttle Control Reduced Power C-09
P1550 Electronic Throttle Control Forced Idle C-09
P1550 Electronic Throttle Control Power Management C-09
P1550 Electronic Throttle Control Engine Stop C-09
P1551 Engine Torque Always Higher Than Expected C-02
P1555 Throttle Position Sensor (TPS) Load Signal not Plausible with Engine Load C-09
P1600 Reprogram or Replace Electronic Control Unit (ECU) C-02
P1606 Replace Electronic Control Unit (ECU) C-02
P1610 Security Code Not Programmed Immobiliser B-07
P1611 Wrong Security Code Entered Immobiliser C-02
P1612 Immobiliser No Or Wrong Signal Immobiliser C-05
P1613 Immobiliser No Or Wrong Signal Immobiliser C-05
P1614 Wrong Security Code received Immobiliser C-06
P1615 Wrong Vehicle ID from Body Control Module C-40
P1616 Wrong Vehicle ID from Instrument Control Module C-40
P1650 Service Vehicle Soon Light Voltage High C-37
P1650 Service Vehicle Soon Light Voltage Low C-37
P1700 SVS request via CAN B-06
U2100 CAN-BUS Malfunction C-05
U2101 CAN-BUS Maximum Configuration List not Programmed C-05
U2104 CAN-BUS reset counter overrun C-05
U2106 CAN-BUS no Communication with TCM B-05
U2108 CAN-BUS no Communication with ABS/TC B-08
Ive had 2 cars do the same thing, 1 was a seat and it was the temp sensor, the other was a corsa and it was the lamba sensor, almost definately sounds like a faulty sensor
Discussion Starter · #10 · (Edited)
This is first thing on my list tomorrow morning!
Code:
Is a lamda sensor the air flow meter? Because that is what he has already replaced, also would that be an expensive job and also will this test work of the engine management light has now went off but the fault is still there?
Pro Spanner Wielder
No its not, the air flow meter, as its name suggests, measures or meters a volume of air entering the engine. The lambda sensor is effectively an oxygen sensor, for determining the amount of oxygen, and hence fuel that is ejected from the cylinders, into the exhaust. The lambda sensor lives mounted in the exhaust, usually on the manifold, sometimes further down the exhaust system.
It's easy to replace, especially for a garage, but buying a proper vaux one will set you back some. Try finding a bosch one on ebay, or if you fancy it, you can get dirt cheap "universal" ones, but i wouldnt recommend that as you're trying to eliminate faults, not introduce more by using crappy products.
Dave.
*EDIT* - and yes, although the light is now off, the ecu SHOULD still have recorded the code, even if its currently inactive, it will be classed as an archived code and should still flash out along with any active codes in the memory of the ecu.
Discussion Starter · #13 ·
Thanks man, the advice is generous and much appreciated. Hopefully somewhere down the line I'll be able to give someone a hand, I'll let you know how it goes
Dave.
Thats my codes
0130
and
0100
Suppose I'm gonna have to leave it in again?
1 - 15 of 15 Posts
