alright got a corsa b 1.2 16v (v grille) i have the chance to buy a 1.6 16v ecotec with ecu wiring loom gearbox ignition barrell+key and all ancilleries will it drop straight in or will i need to get out else
Should be fine. It's a fairly easy transplant to do and you should have all the basics for the conversion.
Just make sure you get the transponder, keychip, and ecu off the 1.6 or you will get problems, apart from that it's pretty much plug and play.
You may need to source the s-bend radiator to thermostat coolant pipe, but I can't think of anything else you would need.
If you get stuck just ask.
yeah ill make sure i get the key ecu n transponder ya no a lot of people that try to do the conversions think that ya can just wire it into your ecu not noing that the ecu has to read the code of the key which ends up having to get ya key reprogrammed £100 a proper ball ache cheers for ya reply
