1 - 10 of 10 Posts
Hi
2004 Corsa C 1.0 manual
About 8 out of 10 times car starts and runs fine.
Other times it starts roughly, with erratic higher than norm revs and with engine electronics light (spanner) staying on.
Take key out and start over and and runs fine.
Fairly sure this is getting worse.
Any tips where to start looking?
Thank you.
Har the fault codes read?
Hmmmmmmmm
"There are no error codes stored........."
Either the car or I am going mad!
The car has a dubious service history, hopefully a decent service may help.
Any other suggestions?
Suggest that, as soon as this condition happens again, you take the spark plugs out and have a look at the business end of them - That may well give you a clue as to what is happening in the cylinders. In any case, especially if it is due, a new set of plugs, with the gap correctly set, may cure your problem.
Regards
It's listed for the Z10XEP but it's probably the same one - they're more or less generic.
But I'd give Autovaux a call on 01924 376003 and give them your reg. no. They'll post you the right one.
1 - 10 of 10 Posts
