1 - 7 of 7 Posts
i am wondering whether to put an exhaust on my diesel corsa as i dont want it to sound like a proper tank but i have heard that a full through system will not make my car acctually sound like a diesel is that true>??
From the back end it will probably sound similar to a normal corsa with a straight through system but it will still sound the same from the front.
dn't go puttin straight thru systems on diesels you will lose every bit of back pressure you ever had and your car will have no power wot so ever!!!!!!!
we've fitted fiesta diesels with straight through exhausts and they go a bit quicker but sound a bit strange, back-pressure on a diesel isn't anywhere near as critical as it is for a petrol whether it's turbocharged or not. if it is turbo'd then as little back-pressure to the turbo is what you want to be aiming for to keep that turbine spinning.
1 - 7 of 7 Posts
