Ok this will be alittle confusing to explain as i am thick so i will try and word it as best as i can
Ok i had a large oval backbox (Alimiumised), with cat back middle section (stainless steel). I noicted with the large oval backbox on it was pulling back slighty, so i then got a stainless steel backbox with a 3'' slash cutt inward role with this the car was fine it didnt pull back... so then i changed the middle section to a custom de cat from front pipe to backbox stainless steel with the silencer only beening the backbox
it sounds really raspy and pops in the lower revs but when you get to higher revs it like a deep sounding noise but i dont really want the rapsy noise as much at all so i might put the large oval backbox back on will this still pull back even though i changed the system? I have also had it chipped and remapped with a bmc filter on since then.
maybe its something i will have to try and if it does then just put the other on back on.
