Hi there my corss been running fine all week then today when we get the hot weather the engine is becoming extremely hot after a 1min drive the cooling fan is kicking in though and the car starts fine then it stays idle for about 10secs then conks out. then i start it back up give it loads of revs and the throttle has extrememly minimum response like my foot flat to the floor then it responds about 3 secs later, the engine light is not coming on though. what can i do?
could it be something as simple as changing the coolant draining the rad changing oil and filters etc? or is this serious?
My Car has been being a gimp aswell.. Only when i start it from warm tho.
Check your coolant and make sure you have enough. could change it too if its never been done before.
You idle control valve could be playing up too if your having idle problems, so check it out too :thumbs_up:
Reactions: simtaylor17
THANKS FOR THE QUICK REPLY!
Well im off too halfrauds via my mates corsa :p going to buy some coolant new oil filter and some oil hope this is the problem also going to sort out my idle valve ill update you soon.
No Problem mate, Let us know how you get on ;)
