1 - 20 of 24 Posts
Just realized today that after my temp gauge goes over 100C the fan isnt kicking in to cool the engine down...i think its been like that a while, maybe a week or so.
The radiator still gets hot and the coolant levels are fine, checked for white foam in the oil and its not present so i dont think its the head gasket, fuse isnt gone either(electric fan).
Any suggestions would help greatly
Cheers
Paul
faulty thermostic switch which is mounted in the right hand end of the
radiator. pass 12v to the fan to see if its still working.
have you checked the fuse for it first?
disconect the wiring plug from the cooling fan switch and bridge the two
contacts with a spare bit of wire,
Il try in the morning for its dark outside now and im in need of sleep, thank you very much for taking the time to respond and help me out, il try that first thing in the morning and post(oh and would it be wise to have the electrics off before i bridge it or would it matter?)
yeah i would, ill be on tomorrow if you need help.
ok, total noob when it comes to this stuff, where exactly is the coolong fan switch and what does it look like? and when you say bridge the two what ya mean by that?
sry for my stupidity :eek:
hang on ill wip the cam out.
quickest way would be to get some speaker cable and touch these two pins with the "+ and -" of the battery doesnt matter witch way around there not polarized and have the ignition off.
what engine do you have?
i remember now, yeah its probably a faulty cooling fan switch
clicky
Discussion Starter · #17 ·
Ok so you think this is what i need? Would i be able to install it myself and where does it go? Also on the site link you sent me it says its for petrol engines with air conditioning, does my car have it? or does it matter? sry for all the questions...
i think there the same on most corsa's email the guy and ask him as im
unshore. it would be screwed into the rad, just unscrew and screw new one
back in.
I had a faulty one of these on mine the other day. Went down local breakers and got it for nothing so mite be worth doin that or go to vauxhall they are only cheap mate.
1 - 20 of 24 Posts
