Dr frankenstein
Fault Codes for an mpi engine. hope this helps
Associated Component/Cause Of Fault
12
Diagnosis Initiated
13
Lambda Sensor (Open Circuit)
14
Coolant Temperature Sensor (Voltage Low)
15
Coolant Temperature Sensor (Voltage High)
16
Knock Sensor 1 (No Voltage Change)
17
Knock Sensor 2 (No Voltage Change)
18
Knock Control Unit (No Signal)
19
Crankshaft Sensor (Incorrect Signal)
21
Throttle Position Sensor (Voltage High)
22
Throttle Position Sensor (Voltage Low)
23
Knock Control Module
24
Vehicle Speed Sensor (No Signal)
25
Injector Valve 1 (Voltage High)
26
Injector Valve 2 (Voltage High)
27
Injector Valve 3 (Voltage High)
28
Injector Valve 4 (Voltage High)
29
Injector Valve 5 (Voltage High)
31
Crankshaft Sensor (No Signal)
32
Injector Valve 6 (Voltage High)
33
EGR Valve (Voltage Low)
34
EGR Valve (Voltage High)
35
Idle Speed Control Valve
37
Fault Code Light (Voltage Low)
38
Lambda Sensor (Voltage Low)
39
Lambda Sensor (Voltage High)
41
Vehicle Speed Sensor (Voltage Low)
42
Vehicle Speed Sensor (Voltage High)
44
Lambda Sensor (Weak Mixture)
45
Lambda Sensor (Rich Mixture)
46
Air Pump Relay (Voltage High)
47
Air Pump Relay (Voltage Low)
48
Battery Voltage Low
49
Battery Voltage High
51
Electronic Control Unit (Hardware Failure)
52
Fault Code Light (Voltage High)
53
Fuel Pump Relay (Voltage Low)
54
Fuel Pump Relay (Voltage High)
55
56
Idle Air Control (Voltage High)
57
Idle Air Control (Voltage Low)
59
Inlet Manifold Valve 1 (Voltage High)
61
Fuel Tank Vent Valve (Voltage Low)
62
Fuel Tank Vent Valve (Voltage High)
63
65
Idle Co Potentiometer (Voltage Low)
66
Idle Co Potentiometer (Voltage High)
67
Throttle Valve Switch
68
Idle Speed Switch (Not Opening)
69
Air Temperature Sensor (Voltage Low)
71
Air Temperature Sensor (Voltage High)
72
Throttle Valve Switch (Not Opening)
73
Air Flow Sensor (Voltage Low)
74
Air Flow Sensor (Voltage High)
75
Auto Transmission Torque Control (Voltage Low)
76
Auto Transmission Torque Control (Ignition Retard Long)
79
Traction Control (Incorrect Ignition/Injection Cut-Off)
81
Injector Valve 1 (Voltage Low)
82
Injector Valve 2 (Voltage Low)
83
Injector Valve 3 (Voltage Low)
84
Injector Valve 4 (Voltage Low)
85
Injector Valve 5 (Voltage Low)
86
Injector Valve 6 (Voltage Low)
87
Air Conditioning Cutoff Relay (Voltage Low)
88
89
Lambda Sensor Heater (Voltage Low)
91
Lambda Sensor Heater (Voltage High)
92
Camshaft Sensor (Incorrect Signal)
93
Hall Effect Sender (Voltage Low)
94
Hall Effect Sender (Voltage High)
97
Traction Control (Incorrect Signal)
98
113
Boost Control (Out Of Range)
114
Boost Pressure Idle (Above Upper Limit)
115
Boost Pressure Full (Below Upper Limit)
116
Boost Pressure (Above Upper Limit)
117
Waste Gate Valve (Voltage Low)
118
Waste Gate Valve (Voltage High)
121
Lambda Sensor 2 (Weak Mixture)
122
Lambda Sensor 2 (Rich Mixture)
123
Inlet Manifold Valve 1 (Blocked)
124
Inlet Manifold Valve 2 (Blocked)
132
EGR Valve (Incorrect Signal)
133
EGR Valve 2 (Voltage High)
134
EGR Valve 2 (Voltage Low)
135
Fault Code Light
136
137
141
Secondary Air Pump (Not Enough Air)
142
Secondary Air Pump (Air Without Pump)
143
Immobiliser Function In Ecu (No Or Incorrect Signal)
144
No Immobiliser Signal Received
145
Incorrect Immobiliser Signal Received
146
i have been given codes for my corsa (2000) sxi:-
U0Doo
U1187 (pd)
u3111 (pd)
C0700 (pd)
U1000 (pd)
any idea what these mean please?
