1 - 8 of 8 Posts
Alright guys completely pissed off with this f**king thing, put so much work and effort into spraying it etc. had to even pay an extra £60 to add it to my policy. went out to fit it and the f**king thing won't fit, it's hitting the wheels and generally won't fit. I can't see why because its made for a corsa b? any advice/tips?
Most body kits seem to be made from cheap materials by people who've never seen the car it's supposed to be designed for. Unfortunately this means they very rarely fit easily.
Only advise I can give you is to keep at it, making slight adjustments to mounts and such. If you're worried about breaking anything or ruining paint then get a body shop to do it.
By the sounds of it, it's probably a good thing.
Reactions: JOJC1313
Discussion Starter #6
Basically its got this bracket thing on each end of the bumper.
It's then got holes drilled on the front end where its attached to where the standard grill is screwed in.
It's got the holes on each side of the bumper where the bolt goes gets screwed into just under where arch attaches to the front bumper.
1 - 8 of 8 Posts
