How the fu*k do you remove then- i tried but the window winder is in the way and along the top looks like its secured on there.
Easy mate here's a quick guide:
1. I'm assumming you have removed the door handle
2. Take the window winder of - to do this pull it and then in behind yo will see a clip - using a very small screwdriver push on 1 side of the clip and it will become visible then just pull clip out - be careful as it can ping out pretty quick and then you use it although you can still put winder back on without it
3. Remove the door pocket - this is fairly straight forward just some screws
4. At the end of door towards back you will see 2 screws that go through the card - remove them
5. the last screw holding the door card on is behind the wing mirror cover
6. Along the top is a rubber strip that seals bit between card and window - wedge it off with a large flat screwdriver
7. All thats left now is to get a hold of the card and lift it upwards - it rests on these clip things so lifting it up takes it off of them and you now have your door card removed
Hope this helps mate :thumbs_up:
Easy mate here's a qick guide:
cheers i'll give it ago tomorrow
