I have a 54 plate corsa.
I went out the other morning and suddenly my front wipers will not work, my rear ones are fine. Checked the fuse and it is fine, was advised it would be the wiper motor as they are prone to go. We have changed this and still it will not work, my partner took the wiper stalk off the steering column and changed that in case it was not still no luck. The only thing now we are think is it could be the relay. We have checked the manuals and there is no indication as to which relay does what. Any help or advise is greatly appreciated as my car is due MOT next and can’t be without a car for work
Thank You
front wiper problem
Hi,did you get to the bottom of the problem with your wipers.I have developed that problem today after the snow.thought it might have blown the fuse but it seems ok. Regards Gary
