Ah right yes i know the little black lid....but is it a wiper fuse?...i think you have a corsa C, i have list of the fuses will try to put it below....if it is for wipers you make a short on them...should be fuse 23, second on in from the yellow relay, under black cover...Fred
Vauxhall Corsa C, 2001, 1 Litre, fuses and Relay's etc.
Fuses
1 Central control unit
2 Engine control unit
3 Instruments, information display, horn, hazard warning lights flashers, immobilizer
4 Number plate lamp
5 Electric window lifters
6 Automatic transmission
7 Headlamp washer system
8 Starter
9 Fuel injection system, fuel pump
10 Horn
11 Central control unit
12 Information display, infotainment system, radio
13 Anti-theft alarm system
14 Exterior mirrors
15 Windscreen wash system
16 Courtesy lamp
17 Central control unit
18 Sun Roof
19 Anti-theft alarm system
20 Window lifters
21 N/U
22 Central control unit
23 Windscreen wipers
24 Infotainment system, information display, courtesy lamp, instruments EPS, Immobilizer
25 Brake lamps
26 (Petrol) cigg lighter. (Diesel) automatic transmission, fuel injection system, reverse lamps, cigg lighter
27 Seat heating
28 Seat heating
29 Windscreen wash system
30 (Petrol) Engine control unit. (Diesel) Engine control unit, stationary heater
31 Air conditioning system
32 Heated rear window
33 N/U
34 Diesel filter heater
35 Tilt /Slide sunroof, window lifters, radio
36 Dipped Headlamp beam
37 Dipped Headlamp beam
38 Tail lamp left, parking lamp left
39 Tail lamp right, parking lamp right
40 N/U
41 Fog lights
42 Fog tail lamp
43 Main beam left
44 Main beam right
45 Air conditioning system, heater blower motor
46 Engine control unit
47 Heated rear window
48 Starter
49 EPS
50 ABS
51 (Petrol) Easytronic. (Diesel) Engine control unit
52 Cooling fan petrol or diesel engine with or without Air Con
53 Air conditioning system (petrol and diesel, different fuses)
Relays
1 Cooling Fan (A) (Green)
2 Cooling fan (C)
3 Cooling fan (D)
4 A/C Compressor
5 Cooling fan (B)
6 N/U
7 ECU (Pink /Purple)
8 Signal converter module, vehicle speed left (orange)
9 Right signal converters
10 Fuel Pump (Pink/Purple)
11 Heated rear window (grey /beige)
12 Washer pump and headlight
13 Auxililary Ignition (yellow)
14 Starter (yellow)
15 Ignition (yellow)
16 Rear fog (small black)
17 N/U
18 PL R Park (small black)
19 High beam (small black)
20 PL L Park (small black)
21 Low beam (small black)
The Box next to the battery, held down with 7 torx screws. (weatherproof when refitting top)
Relays
1 K24D dead lock
2 K24A drivers door
3 K24C unlock
4 K24B lock
5 K74 rear washer pump
6 K70 front washer pump
7 K67 horn alarm
8 K54 licence plate
9 K68B wiper stage 2
10 K47 trumpet horn
11 K69A wiper stage 1
12 K56 rear wiper
13 K66 turn signal, yellow large relay at front, twin section inside cover.
14 N/U
15 N/U
16 N/U
17 BCM (Body Control Module or Multi timer)
..................From Fred in Essex 2017
Quick update. The front wipers must be on a different fuse to the rear as I found a fuse compartment hidden by a cover within the fuse box. There was a fuse blown which is for the front wipers,
Sadly I've replaced the fuse but it blow that too.
