1 - 15 of 15 Posts
Still shouldn't be an issue could go a few ways about it, simplest to explain is chop live wire to fuel pump on top of tank and wire a switch in The middle of it, just means running the wires back and hiding em, or could do it through the fuel relay but that gets a bit more complicated lol
Yeah well u can put it wherever u want depending on the length of the wires :) easiest way will be to go off the plug on the top off the tank, should be 4 wires, 2 for the gauge 2 for the pump, blue and red one is pump live, switch inbetween that bingo
search for fuel realy or fuse -wire and chop that cable as it will be closer to front of car it saves runnings long wires.obviously switch needs to be hidden and in reach of drivers seat
1 - 15 of 15 Posts
