my fuel gauge isnt working nor is my temp, but my speedo is, the fuel one just doesnt move just sits at empty at all times, i was wondering if any one would know what the problem would be, and if i could fix it. its a 95 corsa b i have.
cheers
your fuse could have gone. your speedo will still work because it is cable driven on the early corsa B models. have you had the clocks out recently? the electronic connector may not be in contact with the back of the dials like it should be. the fuel and temp guages are electronic. try taking the clock out and having a look :)
i have checked all the fuses under the dash and they all seem fine, i took the dials out and put them all back in and they are screwed in fine, behind the dials there where three wires that wasnt connected to anything, have they got anything to do with the dials.
cheers
Hi Guys, im KG from South Africa. i have the same problem with my Corsa b and would like to know if you have resolved yours and how. thanks
