Hi,
Wife's Corsa C (Z12XE) has developed a petrol leak and I would like any pointers as to where to start looking. It only happens when car is running and seems to run down the fuel pipe leading to the fuel filter(The hose with the "L" shaped connector to the filter) Not the "Y" shaped one.
I have no idea where this fuel pipe leads up to, it goes towards the fuel tank area but also unsure if it connects to another pipe that I can't see. I had the seat up and looked at the pump access hole, pipes and surrounding areas look fine with no leaks.
Any starting points and places to look would be much appreciated.
Thanks in advance
Tam
Thanks in advance
Tam
