Check at your injectors- should be permanent power (with key on) and a negative pulse while cranking. This is what "opens" the injectors. If there is no power, check fuses. If no pulse, check earths. If problem still persists, could be more serious- ECU or a sensor.
Suggest starting with that test and let us know!
