1 - 20 of 47 Posts
cheers! need to go through mine soon as my centre console dont light up and i think its a fuse!
Does your MFD and radio work?? if yes then its not the fuse..
Thats why i posted it.. so people know what fuse is linked to what.
i just checked all of my fuses as the radio stopped working, and the fuse had blown, in the haynes manual it says that fuse 17/18 should be 10/20A, but on the cover covering the fuse box it says they should both be 15A, does anybody no which one i should follow?
radio permanent live feed
hi the radio p[ermanent live feed in my daughters car a N reg corsa is also on fuse 1
which is good as it just saved the wiring in the car by blowing the fuse when it cam e out of its connector and shorted.... so all minor the things that work with ignition off are protected on this one
cheers
mikey wikey
hi
the radio permanent live feed in my daughters car a N reg corsa is also on fuse 1
which is good as it just saved the wiring in the car by blowing the fuse when it came out of its connector and shorted.... so all minor the things that work with ignition off are protected on this fuse
cheers
mikey wikey
Excellent post thanks for this my reverse lights weren't working and my speedo (not the best trying to guess how fast your driving :laugh:) wasn't working either as i blew the fuse with my neons on and trying to plug somthing in the cigarette lighter wouldve been there allday if it wasn't for this thanks again:thumbs_up:
I have just bought a Corsa 1.0i (B) model 2000 (w) for my son and the horn is not working, I have already checked the fuse (no 1) thats ok and have put a 12v supply direct on to the horn and it works is there anything else I need to check. Thanks any advice welcome
same problem
have you tried looking at the connection to the horn itself? it might have been disconnected?
In the fuse box on the 94 LS can someone tell me where abouts the clocks fuse/relay is... i looked on the diagram and saw where it was but my dads saying "its wrong" so im hoping somebody can comfirm it for me :)
Clock? You mean the MFD or the lights for the instrument panel?
Fuse 17, 10 Amperes
1 - 20 of 47 Posts
