When i first get in my car, the gears are fairly smooth etc...But after about 15 minutes of driving today, i was having to really force it into gear and sometimes it just wouldnt go in, i left the car for about an hour and tried again and the same thing after 10 minutes the gears just wouldnt go in again?:confused: :confused: :confused: :confused:
check the gearlinkage is still in one piece, check the selector pin hasnt popped out.
try changing gearbox oil or just new box.
Where do i find the selector pin? And how do i put new gear box oil in?
selector pin is on the top of the gearbox, might need to take the battery out to ge to it properly. The pin goes through a U shape bracket. The pins arent reuseable but they are £1.47 new from vauxhall. Less if you get trade.
To change gearbox oil on a 1.2 8v im not too sure. Should be a sump plug looking thing on it somewhere.
