I was travelling on a dual carriageway at 70mph when the car started slowing down and behaved like it was in neutral (was still in 5th). I tried taking it out of gear and putting it back in 5th and I tried 4th gear but it made no difference. I rolled into a lay-by and tried moving in 1st gear but it still wouldn't work.
I turned the engine off and back on again, and the gears went back to normal. This happened again the next day when I was going at 50mph. Again, everything seemed fine after turning my engine off and on again.
Any ideas what this could be?
sounds like the clutch, is the clutch slipping, does the pedal feel normal, if its slipping bad it will make a hec of a stink....Fred in Essex
The pedal sticks sometimes but it is a relatively new clutch. Will take it to a garage and see what they think
Thanks Fred
