One of my headlights has dulled, it has happened before so I replaced it which didn't fix it so I fitted new sidelights (I think thats what theyre called) and that fixed it for about 1 or 2 days. it has now gone back to having the headlight dulled but not the sidelight. could it be corrosion or a loose connection and if so would it be on the sidelight or the headlight terminals.
By the sounds of it you've got a bad connection, it could be in the live feed, or more usually in the earth.
(If it was corrosion changing the sidelight wouldn't make any difference for just a couple of days. My guess is that in changing the side light you slightly knocked the bad connection to make it better for a while.)
Try moving the wires & connector block at the back of the headlamp to see what makes a difference - then you'll know where the problem lies.
