I Have A V Reg On A 99 Plate Cora Trip - I Believe Its The Bottom Of The Range ???? - Should The Heater Control Area Light Up ? The Only Thing That Is Lit Is The Rear Heated Window, So Basically I Have Nothing Lit Up , Its Tottaly In The Dark Above The Gearstick Up ! Its A Yes , It Should Light Up, Is It A Fuse Or Bulbs Behind ?
Chris
Yes they should light up. If the fuses are the same for your car as they are for mine (1994 corsa) then if the radio, glovebox light and mfd work, the fuse is OK (they all share the same fuse with the instrument panel lights). The bulbs must blow easily; its a common problem... the only light that works on my centre console is 1 of the 2 bulbs in my MFD.
