1 - 9 of 9 Posts
ok i got a '94 gsi
has got g-max dampers and springs on it
but it doesn't site level why is this the front is perfect but the back sits about an inch too high my pix are in car bit under gsimark's ride have a look and see
bloke at g-max said a gsi can't be lowered 60mm but i have a mate who's is perfectly level but he can't see what is on his
would it be sitting on the bump stops or do i need shorter dampers even more
it is annoying the hell outta me please guys throw some ideas my way
Is it a full gmax suspension setup or just springs?
Did you replace the bumpstops with uprated ones or cut the originals down when you put the suspension on?
i used 60mm g max and mines was lower at the front but mines is a 2.0, had them on a sri corsa and left about an inch of bumpstop :)
d
Discussion Starter #8
have taken bump stops out and it sits about 4mm lower there is a diff of 12mm in the height from front and back going to call g-max and see what i can do
You need bumpstops in if your going to drive it though. I'd suggest trimming them down (cheap option) or fitting uprated ones.
1 - 9 of 9 Posts
