1 - 1 of 1 Posts
Hi,
It is a Corsa B 1.4l. Also there is a blue connector (just behind the oil filler cap), does anyone have an idea where it goes? Another problem I have is that the local mechanic's Autel Maxisys Ultra does not communicate with the car.
From the air cleaner box the components are as follows (correct me if I am wrong): Air Intake Temp sensor then the idle control valve then the throttle position sensor? Does it have an Manifold Absolute Pressure sensor and a Mass Airflow sensor? Where is the cam position sensor?
Sorry for all the questions.
I would really appreciate if someone can identify the engine code for me.
Wheel Tire Land vehicle Vehicle Car
Motor vehicle Hood Automotive tire Vehicle Wood
Motor vehicle Vehicle Automotive exterior Automotive fuel system Automotive air manifold
Motor vehicle Automotive design Auto part Automotive tire Automotive exterior
Car Motor vehicle Hood Vehicle Automotive design
1 - 1 of 1 Posts
