1 - 7 of 7 Posts
Basically, iv had my corsa B 1.2 16V R reg for 3 or 4 months now and up until last month it has been running fine. The problem i am having is that when starting the engine the car makes a low rumbling noise and ticks over below 1000 rpm. I have been told by a friend that it is the inside two cylinders that are not firing. I have checked the water and oil levels and everything is fine. I popped the bonet and when the car was on, the engine was shaking quite a lot. and also the exhaust is blowing and sounds a bit like a tractor when i go to pull away. When i do go to pull away however, the car shakes and jolts. Has anyone else had any trouble with something like this??
Discussion Starter · #2 ·
In addition, there was faint white smoke coming from the engine when i popped the bonnet, and also like a burning smell.
where abouts on the engine? sounds like an exhaust leak which is affecting lambda sensor readings causing missfiring.
thanks everyone, reference; Marc24: i have been suggested to change plugs and possibly a new ingnition coil. and yes the engine managment light did come on once this morning, but since then it hasnt come on. can you suggest anything else?
yes ive had the same problem i have a 12v 3 cylinder engine and ive been told one of mine are mis firing. I also have the faint smoke under the bonet and when looking about i found a crack going around a part of the catalytic converter. Try looking from under neath and folow from you cat up to the engine bay checking the pipes i found it on an oragngey colour cylinder right by my radiator. Could be the problem to your smoke, so i recoment you get it looked at by someone who knows what they are looking at, i had to replace my whole cat. Converter with a new gasket. Good luck :)
1 - 7 of 7 Posts
