Hi all,
I have a 52 plate Vauxhall Corsa 1.7 CTDI.
It has run fine for quite some time. However just before Christmas the alternator went, which I had replaced at considerable cost (over £300).
The car was fine for a week, but I was driving along and suddenly it lost all power.
I stopped at the side of the road and the car was revving on its own at 1500 revs (pulsing) and the car management system light was showing on the dashboard (the yellow spanner). If I press the brake, the revs drop down to normal when stopped.
When I tried to drive it, I couldn't get the power over 2000 revs (revs would stop increasing - as though the ECU was stopping it), which meant the only way I could drive it was to shift the gears up until the anti-stall kicked in and forced the car to accelerate. I also can't get it up hills unless I crawl along at about 10 mph.
I took it to a specialist auto-electric centre. They thought they'd solved it after several days of checking - found some wiring that was corroded and was causing the ECU to short out (something to do with the earthing of the ECU).
They rang me and said it was fixed so I went to pick it up, but as soon as I turned the ignition the car was doing the revving on its own again. They plugged in the diagnosis kit and said there were originally two codes - one has been fixed and no longer showed, but the other one still showed up on their display (related to the ECU).
They told me that they'd driven it about 5-6 miles without any problems, and seemed to think the shorting may have damaged the ECU - but the fact it drove for so long suggests it may not be broken?
I've paid over £200 so far and it has the mechanics scratching their heads. They said they could try updating the software in case the shorting caused the files to corrupt (at additional cost). Otherwise it's going to cost me £700 to replace the ECU (again no guarantee of a fix), but the car's barely worth £600, so not really worth doing.
Has anyone experienced the same symptoms, and could suggest what the problem is, and possible the fix?
I've done some research online and the revving seems to be a common problem with Vauxhall cars, but no-one else's symptoms seem to match mine exactly, nor does there seem to be a consistent fix for it. The garage had checked the sensors around the accelerator apparently and couldn't see anything wrong (that's not to say it's not this!).
Thanks in advance for any help or advice given!
Costello
Costello
