hi, i have a corsa b. 2000 mod. my dashboard does not have a tachometer... only fuel meter, temperature and a speedo. so my plan is: buy a dashboard from a corsa 1996 witch has a tacho, a speedo, a fuel meter and a temp gauge. will this work? or will the result be that the speedo will work as normal an the tacho wont work at all?
this is what i have today: http://www.ebay.de/itm/Opel-Corsa-B...del:Corsa+B&hash=item337de32fc0#ht_500wt_1288
and this is what i want to install instead: http://www.ebay.de/itm/Opel-Corsa-B...del:Corsa+B&hash=item337de32fc0#ht_500wt_1288
thank you very much for any help :)
You've linked to the same item twice there.
It's a straight swap for most Corsas. Some need an extra wire running from the ECU to the clocks, but the vast majority have it already.
You also need to check wether you have an electric or mechanically driven speedo. Electric ones start at 0mph, mechanical start at 10mph.
Only other thing is there's 3 different tachometers, the diesel one, the 3 cylinder petrol (1.0 12v) one and the 4 cylinder petrol one (all other petrols).
I don't know what any of that says haha.
Aslong as you buy a 1.0 tacho if you have a 1.0, or any other if its not a 1.0 then it should be fine.
