1 - 1 of 1 Posts
Ok so as some may know I bought a knew corsa today and am trying to sort out the problems although be them small and bearable
Ok so the key fob will happily lock the doors via button no problems however if I try to open the doors it decides to open lock open then finally lock it's self. Also if I put the key in to open it will only open drivers door not passengers but if I do it a few times it will eventually open. I don't know if this matters but when you shut the door it locks it I know this was a safety precaution on a b is it also on the c aswell? Help would be greatly appreciated
1 - 1 of 1 Posts
