1 - 7 of 7 Posts
tried replacing my bulbs behind my centre console, managed it, after a lot of lost scrws and broken plastic, and pout it all back and they dont work!
plus how the hell are you supposed to get the middle heater knob out? i broke mine doing it, so if anyone got the knob and switch, pwwweeez :)
The middle heater knob is removed by pulling it on (as if to demist the rear window) and then you should see a small gap at the bottom, slide a small flat headed screwdriver into here and then you should hit a lug on the middle of the heater, this is what holds it in.
If any of that made sense, I would get pics but I have no car currently.
once that is off
you have to remove the connector
so you can actually pull the console out without trying to pull it out with the connector still attached
lol i went a bit cowboy, i not need a new knob and connector.. anyone got one lying around?
lol mate that is 1 thing i learnt in the past is just take your an get a haynes manual alot of help if your doing things yourself
1 - 7 of 7 Posts
